3054 starter noise
/ 3054 starter noise #1
wanasrx
NY
Kioti 3054
The other day I went out to start the tractor. It was around 30 degrees. I hit the glow plugs a few times before starting. When I hit the started it turned over(slow) and then the starter made a nasty grinding noise. It's been ok during the warmer temps. After pluging it in for a while she started right up, no problem. What do you think? Starter going? can it be rebuilt? bad ring gear? /forums/images/graemlins/confused.gif
/ 3054 starter noise #2
They can be rebuilt. Could be the starter gear... noise could have been caused by low batt.... might have have been getting enough juice to spin right... If it still makes noise with a full batt i would look at the start gear or solenoid. these are the 2 most common parts we replace.... only sold 2 starters ever /forums/images/graemlins/wink.gif.... pretty tough starter...
/ 3054 starter noise #3
Sounds more to me like a low battery and the starter was kicking out..
The motor shouldn't turn over that hard at 30 degrees.
I would charge the battery at check the cable connections and see what it does before messing with the starter.
My 2 cents..
Thanks for the replies. Sounds like it's the battery. Also, I'm glad the starter can be rebuilt when needed.
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
1988 23ft Stealth Craft Boat w 1988 Arrow 22ft Boat Trailer (A61574)
1988 23ft Stealth...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2014 Buick Encore SUV (A61574)
2014 Buick Encore...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
