Oil & Fuel 3054 spitting oil from valve cover tube.
   / 3054 spitting oil from valve cover tube. #1
1hitechredneck
I have a 96 Kioti 3054 that spits oil from the tube that comes off the valve cover area. Have to add oil (40W) about once every 1 1/2 hours of use. I was told it was "blow-by". Everything else seems to work great (PTO, FEL, etc). Has approx 450 hours on it. Sure could use some suggestions. Other than that, I love the tractor.....
Thanks
Norm
   / 3054 spitting oil from valve cover tube. #2
Thanks
Norm
Yep, certainly sounds like "blow-by" which can only be caused by faulty rings and/or cylinder walls. It sounds like you're not the original owner, in which case, did you get it from a dealer or private sale? If a dealer, and you haven't owned it too long, I'd check with them;if a private sale, I'd guess your SOOL. The only cure is an extensive and expensive re-build :(
Thanks very much for your reply. You're correct, I'm not the original owner. Bought the tractor last month for $4K with an FEL. From what you're saying, this fix could cost a bundle. Would it be worth the investment? I also bought a trailer and a new 5' bush hog after I bought the tractor. There is a local dealer about 5 miles away.
Norm
   / 3054 spitting oil from valve cover tube. #4
With the low hours on the tractor, you may be looking at simply a bad or broken ring. That isn't too big of a job to do yourself (afternoon in the barn). You will know if the cylinders are bad when you pull the head, but I would expect a bad ring set in one of the cyclinders. It only takes 1 to cause the excessive blow-by.
Take care of it now. You'll be better off.
200387 (A51247)
200387 (A51247)
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2019 JOHN DEERE 8295R LOT IDENTIFIER 170 (A53084)
2019 JOHN DEERE...
