3054 out of pond and smokin
   / 3054 out of pond and smokin #1
kiotirules
georgia
kioti lk3054 4x4
hi, i have been cleaning water out of everything, it got everywhere. i can crank and run tractor now. i changed injectors, all fluids, cleaned fuel tank. when i first start i get thick white/blue smoke, after i run tractor around, maybe 30 mins, it gets better, if it sits idleing the engine will rev alittle and go back to idle and repeat, it also has a small skip. all help appreciated!!
   / 3054 out of pond and smokin #2
Did it get deep enough to get the injector pump under the water?
oh!!! it went totally under, all but canopy.
   / 3054 out of pond and smokin #4
If you did indeed get all of the water out, I wouldn't be surprised if the pump is shot. When cold water hits a hot pump sometimes it will close up the tolerances. I would say to take it off and take it to fuel pump shop and let them check it out.
Sorry to hear about your bad luck.
it was idleing when it went into the water, i've checked all i know to check, i first drained the oil, removed the injectors and turned engine over to blow water off pistons, replaced injectors with new ones, i know 1 was bad, i did pour alittle oil in every cylinder and was wondering if this may be causing the smoke, the fuel response is slow at first but once at full throttle it is good.
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
TRUBILT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
TRUBILT SKID STEER...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 84"...
New Calf Hut (A50515)
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
