3054 out of pond and smokin
   / 3054 out of pond and smokin #1
kiotirules
georgia
kioti lk3054 4x4
hi, i have been cleaning water out of everything, it got everywhere. i can crank and run tractor now. i changed injectors, all fluids, cleaned fuel tank. when i first start i get thick white/blue smoke, after i run tractor around, maybe 30 mins, it gets better, if it sits idleing the engine will rev alittle and go back to idle and repeat, it also has a small skip. all help appreciated!!
   / 3054 out of pond and smokin #2
Did it get deep enough to get the injector pump under the water?
oh!!! it went totally under, all but canopy.
   / 3054 out of pond and smokin #4
If you did indeed get all of the water out, I wouldn't be surprised if the pump is shot. When cold water hits a hot pump sometimes it will close up the tolerances. I would say to take it off and take it to fuel pump shop and let them check it out.
Sorry to hear about your bad luck.
it was idleing when it went into the water, i've checked all i know to check, i first drained the oil, removed the injectors and turned engine over to blow water off pistons, replaced injectors with new ones, i know 1 was bad, i did pour alittle oil in every cylinder and was wondering if this may be causing the smoke, the fuel response is slow at first but once at full throttle it is good.
(2) TW 30 FORD WHEELS (A60432)
(2) TW 30 FORD...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
John Deere 5525 (A60462)
John Deere 5525...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
