3054 ignition problem
/ 3054 ignition problem #1
sigma6
Will not start. Does not seem to be getting 12vdc from ignition switch to solenoid. Does anyone know if this line is fused? All the fuses I found are good. A schematic would be great if someone has one. Thanks.
/ 3054 ignition problem #2
Are you getting any power?
Do the lights work?
Did you make sure your shuttle lever is in the neutral position.
Just some basic questions.
lights work. Shuttle lever correct. everything seems to be coming on, except starter. I measured the the voltage on the small wire on solenoid and I have 0 vdc. I applied 12vdc to that wire and it fires right up.
/ 3054 ignition problem #4
I would guess it's your safety switch; clutch. Make a small jumper(I use 12ga. house wire) and bypass the switch where it plugs into the harness, under the left floor board. I don't believe there is a shuttle safety switch. If this doesn't solve your problem, I'd look at the ignition switch
/ 3054 ignition problem #5
Sounds like you're close to solving the problem, so I digress.
Your choice of ID intrigues me (as a retired Six Sigma Master Black Belt). Are you a disciple? If your answer is a long one, please send it via PM.
Best regards, John A.
STORAGE FEES (A59914)
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
Steel Wheelbarrow (A65640)
Steel Wheelbarrow...
2012 Audi Q5 3.2 Quattro Triptronic (A62679)
2012 Audi Q5 3.2...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
New/Unused AGT Industrial SDA-140T Track Loader (A65583)
New/Unused AGT...
