3054 Axle seals
/ 3054 Axle seals #1
Jim_in_Omaha
Omaha area
LK3054
Anyone replaced these seals? Mine started leaking last winter on both sides.
I was wondering just how involved it is.
Thanks...
/ 3054 Axle seals #2
I replaced the "floating seals" on the left side of my CK30. It was pretty easy. The 3045 doesn't look all that different. I ordered the parts from Wallace Tractors. I told them what I planned to do and they sent me all of the seals I needed to get the job done. They really didn't cost that much. I bought both the parts and maintenance manual before I started. The parts manual was the most help but one or two of the rings did not show up on the diagrams. Invest in a good set of snap ring pliers. There were several very hefty snap rings that had to come out. Both inside and outside rings. When I put it back together I used a ratcheting tie-down strap to hold the assembly together while I installed one of the retaining snap rings. All and all a relatively easy job. Take that axle end assembly off of the tractor and put it on a bench to work on it. Keep track of the order the gears, rings and seals come apart for reassembly. Plan on not using the tractor for a couple of weeks in case some unforeseen parts need to be replaced and you have to order them. I would definitely do it again myself if I had to do it again. It was fun seeing how the gears go together inside there. I kind of wondered how it worked when I looked at it from the outside. Now I know. There was a seal that I did not replace which as it turns out wasn't leaking. It is a large o-ring that fits into a grove on a metal ring. To remove it I would have had to have the metal ring pressed out by pushing on an inner race of a bearing which would have ruined the bearing and I did not have a replacement bearing on hand. It's not leaking so that o-ring still must be good.
/ 3054 Axle seals
twigpig said:
So Jim. Did you replace those axle seals?
No not yet. I gave the tractor its bi-annual bath with the power washer. Cleaned everything up good. I noticed it is not dripping right now. It will start again I'm sure.
/ 3054 Axle seals #5
Maybe not. If you just had a couple of grains of sand between the two metal floating seals the sand might have worked its way out and the floating seal is back to smooth metal against smooth metal and it wont leak until you get sand in it again.
