3038e w/ snow plow hydraulics question
   / 3038e w/ snow plow hydraulics question #1
Walker332
Stowe, VT
John Deere 3032e
I have built a FEL mounted plow using an old fisher snow plow that I cut down. Ideally I would like it to be power angle. Is it possible to connect the plow cylinders to the roll function of my FEL? One cylinder to the end of the roll circuit and the other cylinder to the end of the curl circuit? If that makes any sense, is it possible?
Thanks in advance for any help. :thumbsup:
   / 3038e w/ snow plow hydraulics question #2
It is possible, but I don't quite understand the way you want to plumb it...you will have to disconnect the curl circuit from the tractor and hook up the plow cylinders, but sometimes the curl cylinders will leak down some.
I believe you have the #305 loader, and I think that has a 3-way valve (regen all the time) that will prevent the use of a diverter or even just the valve itself since both lines will be pressurized.
If I disconnect the curl cylinders when they are fully retracted, I would think they would remain that way. If I do it the way I hope, the curl movement of the joystick would angle the plow left. The roll movement would angle the plow right.
Does that help at all?
1999 CATERPILLAR TH82 TELESCOPIC FORKLIFT (A51242)
1999 CATERPILLAR...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
