3038e front axle leaking
   / 3038e front axle leaking #11
Mine has since started again. Not sure if it's vented but it should be. Adding a vent shouldn't be that much of an issue.
My b8200 had a rubber hose on a hose barb for the rear end. That was broke off when I bought the machine. I tapped it out to 1/8in not and used two 90* fittings and a plug with a small hole drilled in it to make my own.
If you can still and tap the fill cap on the bench that would be best.
   / 3038e front axle leaking #12
I purchased the John Deere vented metal dipstick a few years ago, unfortunately both my front axle pivot points are still leaking, strange that even when I remove the vented seal I still get some air/pressure release from the opening, tried blowing out the vented dipstick to see if it might be plugged, time will tell. Does anyone have a breakdown on how to replace the front axle seals?
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2019 Grove TMS500-2 40T Crane (A60460)
2019 Grove...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
