3038e Driveshaft seal leak
   / 3038e Driveshaft seal leak #1
omrebel
SOUTH MS
JD 3038e
My rear seal for the driveshaft for the front wheel drive is leaking. I guess a stick pushed it in because the bottom is in 3/8in too far. Has anyone replaced one of these? It looks like it is installed from the outside but I'm not sure how to disconnect the driveshaft. It has a joint about 4 in long with what looks like a small set screw holding the driveshaft to the output shaft. I don't have a shop manual and don't want to pay $300 for one to replace a $15 seal. Any help would be appreciated.
   / 3038e Driveshaft seal leak #2
omrebel
From jd Parts, looks like the seal should slip right back in, after old one removed.
Looks like a spring pin (4 x 30 mm) driven through the collar holds the stub from the tranny and the drive shaft together. Will take a punch close to that diameter to drive it out. Looks to be the same or similar on both ends of the drive shaft.
Thanks-That's what I needed I think. It's not a set screw just a pin you drive out. I couldn't get my light and my glasses lined up well enough to see it.
   / 3038e Driveshaft seal leak #4
Were you able to replace the seal without having to remove the housing? I have the same issue but think the seal is only replaceable from the inside which means the housing has to come off. F3B7F2E8-F8DF-4403-BEEF-6664257270CE.jpeg
   / 3038e Driveshaft seal leak #5
We’re you able to get seal off from outside or did you have to break down the housing?
SKLP Massage Chair (A57149)
SKLP Massage Chair...
AUGER (A58216)
AUGER (A58216)
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
1994 Chevrolet Silverado Suburban (A57148)
1994 Chevrolet...
2017 BX2680 Sub Compact Utility Tractor (A56436)
2017 BX2680 Sub...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59575)
2005 INTERNATIONAL...
