3033R backup alarm
   / 3033R backup alarm #1
pwdby460
Canton, MS
John Deere 3033R
Hi,
I know I'm crazy, but I would like to install a backup alarm on my 3033R open station tractor. I purchased the kit and the tech manual. It shows that there should be a plug with orange and black wire on the right side by rear fender. I found a plug for the work lights and a plug for the diverter valve (white and black wires) but no luck on the orange and black wires for the backup alarm. Can anyone tell me more precisely where it might be? A picture might be a great help also.
Thank you,
Dan-o
   / 3033R backup alarm #2
For a wiring schematic, you likely have found that in the tech manual.
Also, there is a 12V light probe with a very sharp pin-point that is useful when tracking hot wires. Just stick it gently through the insulation and it will light up. I find it very helpful.
:welcome: to TBN
   / 3033R backup alarm #3
Look over to the left, near your transmission dip stick,
   / 3033R backup alarm #4
that kit is the same from the 20 series, but they may have made changes to the harness with
the new models.
the new models.
Hi All,
The kit is listed under my tractor model. I think the kit part number is LBV25607. I started to look on the left side but may not have looked hard enough. I looked real good on right side, almost to the point of even removing the wheel. I have the tech manual and it shows the wiring harness and connectors and it shows it to be on the right, but we all know errors can be found in most manuals. Especially on a newly introduced model. I will look harder on the left side tonight.
Thanks for the help!
One thing I forgot to mention, this is an open station 3033R. The cab model has a different wiring harness and some plugs are in different locations
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2018 Infiniti QX60 AWD SUV (A51694)
2018 Infiniti QX60...
2025 K1220 UNUSED Single Garage Metal Shed (A53117)
2025 K1220 UNUSED...
4X8 PUMP (A53843)
4X8 PUMP (A53843)
2010 LOAD MAX 40 FOOT GOOSENECK (A53843)
2010 LOAD MAX 40...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
