3032E pto problem
   / 3032E pto problem #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
The pto on my neighbors 3032E won't engage. My knowledge of these newer tractors is limited. I suggested cheeking fuses,seat switch,pto switch. Does this tractor have a pto speed sensor?
Thanks,Jim
   / 3032E pto problem
What linkage are you referring to?
Thanks for reply,Jim
   / 3032E pto problem #4
I am not sure if a 3032e is like my 2025r but there is a lever that controls mid pto, rear pto or both. If that linkage was messed up it could cause problems, like being stuck in between gears. My tractor has a button to push to start the pto, wiring could be a problem for that. Some tractors have a mechanical linkage to a lever instead to turn the pto off and on, that could be messed up.
   / 3032E pto problem
Thanks for reply. I just got back from delivering my neighbor a rd bale of hay. I checked all 6 fuses that I could locate & they were good. I'll advise them of possible linkage.
   / 3032E pto problem #6
If you're looking for something specific let me know. I have the service manual on CD for the 3025/3032/3038.
   / 3032E pto problem
Wibb
Thank you for the offer. Could you tell me which fuse is for pto circuit & where pto relay is located?? I checked all fuses I could locate. I have no experience with this model of tractor. I'm just trying to help this neighbor lady that her husband passed recently.
Thanks,Jim
   / 3032E pto problem #8
I'll check it tonight. Shoot me an email if you want in a PM and I'll get you copies of the pages
   / 3032E pto problem
Please check your inbox I sent you a PM.
Thanks,Jim
   / 3032E pto problem #10
Lots of info sent. I sent the harness showing the solenoid and PTO switch as well as the schematics and switch pinouts. Hopefully that will point to a wiring issue that can be solved easily. If not I can send over the ICC pins behind the cluster and dig deeper. Let me know how it goes. Good luck
2015 Ford Escape SUV (A48082)
2015 Ford Escape...
2023 Vivid EV Golf Cart (A48082)
2023 Vivid EV Golf...
2013 Mitsubishi Fuso FEC72S Landscape Sprayer Truck (A48081)
2013 Mitsubishi...
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
