3032e 50 hour service - lube and check only?
   / 3032e 50 hour service - lube and check only? #11
Good to know, thanks. I'd expect factory oil to be break-in oil. I would have never thought that it would take 100 hours to break an engine in. I found another reference where Yanmar didn't recommend use of synthetic oil until after 250 hrs to ensure proper break-in.
My dealer said that after 100 hours I'd be good with Synthetic... Really depends on what & how you use it...I purposely gave her a workout with the snowblower last winter, and the break in oil helps with breaking em in. I can see Yanmar's recccomendation when using normal oils because normal oils are so good these days.
At the link provided for the break-in oil they say "John Deere" engines specifically. I'm wondering if these means Yanmar engines or not. From what I can tell on their website the larger engines aren't made by Yanmar.
I wouldnt be worried, IF it were a no-no, you'd think they would put a warning saying "not for use in Yanmar engines". My dealership said it was used in EVERYTHING from a pushmower up to the big boy machines were factory filled with Break In Oil...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
