3032 help
   / 3032 help #1
ericsloan
hamptonville, nc
jinma 354 le
I have a 3032 and in need od some help, after parking one day tried to start again but starter just barely tries it never makes 1/4 rotationand stops. I am assuming all sensprs are made because it tries the voltage starts then goes to 11.5vdc on two batteries im thinking connections at starter does anyone have outher ideas.
   / 3032 help #2
Clean all battery cable connections for starters, what I'd suggest.
Then get the battery load tested.
If older than 4 years, suspect new one needed.
Dig deeper if still a problem. .....just my initial ideas..
   / 3032 help #3
I'll go along with "beenthere" but add you should be sure battery cables are properly tightened and trace your ground wire to the frame. Clean it and make sure it's tightned securely.
   / 3032 help #4
Have you tried to jump-start the tractor from another vehicle or a battery booster? If a jump-start works to start the engine, you need a new battery. If the jump-start does not work, look elsewhere for the issue with electrical cables, connections, starter motor.
Good luck!
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2008 Cadillac Escalade ESV 4x4 SUV (A51694)
2008 Cadillac...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
Michigan L-90 Wheel Loader (A52384)
Michigan L-90...
