3020 PTO Clutch
   / 3020 PTO Clutch #1
Draagyn
Woodpecker, Canada
65 JD 3020, 75 IH 966
Was cutting hay yesterday and sounds like the PTO clutch is making slipping noises. I was wondering if there is any adjustments I can make to put more pressure on the clutch. Was thinking about shortening operating rod. Thanks.
   / 3020 PTO Clutch
   / 3020 PTO Clutch #3
The operating rod can be lengthend to apply more pressure on the PTO disc. You should check the PTO adjusting screws that they are even and one hasnt
come loose , remove the cover under the clutch assy and by turning the flywheel you can inspect the PTO operating levers.
   / 3020 PTO Clutch
Thanks for the info, didn't know that inspection cover was there. At first glance everything looks tight but there is an oil leak in there somewhere... Will be looking into more soon.
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
72in Dual Cylinder Grapple Skid Steer Attachment (A51691)
72in Dual Cylinder...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
