3020 JD Tractor issues, brakes, drive ect
   / 3020 JD Tractor issues, brakes, drive ect #1
jlfarms
Indiana
JD 3020
I have a JD 3020 according to the chassis number it is a 656800 so I assume a 1965 model, Row Crop, Diesel, Syncro Range Trans.
Here is my problem while using the brake pedal locked up not sure if it was in the up position or down brakes did work prior. I did try to bleed and got signs of water in hydro oil. So I changed the oil and the filter, 1 large drain plug close to the back and a small plug that was more up front. Put in new filter and oil although I did not use the JD brand special oil the owners manual suggested but a compatible from a local farm store. When this and a couple of other maintenance projects were complete I started the tractor and ( the hydraulics were always a little slow starting, take a few minutes for the steering, 3 point lift, and loader to activate but they did start working. So far so good. I let run for a few more minutes since I had changed the hydro oil and also engine oil.
Here is what I have now, the brake pedal is still locked wont move up or down also the transmission will not engage on the left side of the shifter panel but will engage an move the tractor on the right side of shifter panel which includes 3 and R and 5 and R. Any ideas would be appreciated. Also I need to mow would I be safe to use the 3 or 5 which are what I generally use anyway or will it burn something up. And it would really be great to get the brakes working.
Oh and once while pulling someone out of the snow it seemed like one wheel wanted to lock up. What about the differential lock pedal? If it was to get pushed could this be my brake issue?
   / 3020 JD Tractor issues, brakes, drive ect #2
Look at my reply to your same question on hyd forum.
Thanks
   / 3020 JD Tractor issues, brakes, drive ect #4
A link to that reply would be very helpful.
   / 3020 JD Tractor issues, brakes, drive ect #7
Coby linked it, and many thanks for the help to the OP. ;)
I also have no idea about posting a link. Thanks C0oby.
Tx Jim I do not find a grease fitting for the brake pedals. Also I incorrect in the location of the pedal. They are in the all the way up position. I am going to work on the pistons as suggested but have lots to remove to get there. JD hides things well and old tractors have things like rounded and striped nut's. The only way I can see to get to them (pistion's) is to remove the platform. Somebody did not do a very good job last time. Currious do you think I would be ok to go ahead and use in gear 3 or 5 on the right side of the shifter? Linkage is well hidden also. Thanks
   / 3020 JD Tractor issues, brakes, drive ect #9
I think if you'll re-read my reply you'll determine I stated lubricate brake pedal pin but made no mention of GREASE ZERT(fitting).
2011 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2011 DRAGON...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
2016 KENWORTH T270 SERVICE TRUCK (A51406)
2016 KENWORTH T270...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
