3020 has oil blowing out of the exhaust
   / 3020 has oil blowing out of the exhaust #1
gengine
Platinum Member
Western Wyoming
Which one?
I have a '65 Deere 3020 diesel non-turboed that I had plugged in overnight to fire up the next morning to push snow. All of a sudden after 3-4 minutes of running to warm up, tractor hadn't moved yet, it started smoking like an old steam locomotive. I went over to it and oil was blowing out of the exhaust. I shut it off and after a bit checked the oil which was two quarts low, when it was up to the top of the hatches before I started it. It never burned oil before. Where should I start?
This is running on all four cylinders just fine, has a hard time revving up but I'm sure that's because of the oil. I haven't let it get hot enough for a runaway. I am also thinking valve stem seals, but I didn't know if there was somewhere else that I should check first. I am a heavy equipment mechanic, and this is a little engine by what I work on most of the time. My first thought was turbo, but there is none. My second was valve seals, or worse, a cracked head. I'm just curious if there is something I'm missing before I do a tear down. Any thoughts and insight are appreciated.
   / 3020 has oil blowing out of the exhaust #4
might do a compression check to start if you can get the right gauges, procedures
best of luck
   / 3020 has oil blowing out of the exhaust #5
Clogged crankcase vent?
   / 3020 has oil blowing out of the exhaust #6
I have a Honda tractor and it would blow oil smoke in huge clouds from time to time. The oil level would drop quite a bit when this happened. The culprit was valve stem seals. My son replaced them and now it never smokes and does not use oil.
Eric
   / 3020 has oil blowing out of the exhaust #7
What is your Honda tractor? Engine? HP ? Model #?
   / 3020 has oil blowing out of the exhaust #8
The 3020 Deere is a heck of a lot bigger than a single cyl Honda, but engines are engines. Valve seals are very likely in both cases. I didn't think about what Hay Dude said about crankcase vent...
Been There and Big Bubba, my compression tests from 1-4 are: 325, 317, 321, 330, so I am not thinking it is a ring or compression issue, what do you think?
   / 3020 has oil blowing out of the exhaust #10
Pull the exhaust manifold and check the ports. If it's smoking that bad you might be able to see the oil coming down the valve stem or stems.
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
1264 (A50490)
1264 (A50490)
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
