3020 Diesel will not statt
   / 3020 Diesel will not statt
Does the starter turn over the engine. If it does not check the starter to make sure it is all okay. If it is don’t try and start the engine. Remove all the injectors and then roll over to expel any fluid. Then figure where the fluid is coming from and fix that.
If there is fluid lock and the engine starts it can cause serious damage.
It does try to turn the engine over....but it’s almost like it don’t have the power! I put new batteries and heavy duty cables on it and it does the same thing. I’m pretty sure that there’s fuel in the oil again because the oil is REALLY thin and I use ROTEX oil! I’m like you though...it may be starter is just too weak to turn that engine over. Gonna do more troubleshooting on it today
2008 Ford F-250 Crew Cab Pickup Truck (A55852)
2008 Ford F-250...
SAMSUNG FRIGERATOR W/ DRAWER FREEZER (A57192)
SAMSUNG FRIGERATOR...
Golf Cart Cargo Box (A56469)
Golf Cart Cargo...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
WET LINE PUMP (A57192)
3pt 2 Row Plow (A53317)
3pt 2 Row Plow...
