3020 Clutch pedal sticking
   / 3020 Clutch pedal sticking #1
Ihturnedjd
Sedalia, CO
JD 3020 and JD 5205
Hello,
First time to post a note. I have a nice 1963 3020 synchro that looks and runs great. I have just started to have problems letting out the clutch. It disengages okay but when you let it out, it stops about halfway and will eventually come up fully but can pop the clutch and a little dangerous. Each gear works fine and everything operates as it should. Any ideas before I have someone split it open? I did make sure hydraulic oil is full.
Thanks,
ihturnedjd
   / 3020 Clutch pedal sticking #2
:welcome: to TBN
Is clutch pedal return spring(parts key 2) in place and not stretched out? If spring is attached & not stretched out then I'd suggest to remove inspection cover in the bottom of clutch housing for a visual inspection of clutch control components.
R26833 Extension Spring - SPRING ADD 16.75 USD
Ok thanks a lot for that! The spring needs to be replaced so I will do that first. The one on it does look old and flimsy. Dumb question: does the main hydraulic fluid share lubrication for the tranny? Could that be a problem that it's not getting properly lubed??
Thank you again
   / 3020 Clutch pedal sticking #4
Trans & diff share the same oil. Clutch housing is a separate compartment that should have no oil in it.
Ok thank you again. It's a great cutting and baling tractor and general use for what I paid and I just want to keep it going.
   / 3020 Clutch pedal sticking #6
Shaft #8 is probably sticking in the clutch housing. Spray some penetrating oil on both ends and work to pedal up and down while lubing. That will probably help. Also have you removed the bottom cover and lubed the throw out bearing grease fitting? The pto bearing has a remote fitting on the outside of the clutch housing. These fittings also grease the slide tubes to make things work smoothly.
jd110,
Thanks for the info. Will try it this week. Great guys here on the forum.
THANKS jd110!!
2025 Mower King SSEFGC175 (A50123)
2025 Mower King...
2011 Honda Pilot EX SUV (A53117)
2011 Honda Pilot...
2016 Ram 2500 Truck (A52384)
2016 Ram 2500...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
Bush Hog 20' Mower (A50123)
Bush Hog 20' Mower...
2018 HINO 195 16FT BOX TRUCK (A53426)
2018 HINO 195 16FT...
