3016 Weight With FEL and Backhoe
   / 3016 Weight With FEL and Backhoe #1
Kryton619
Ontario, Canada
Mahindra 3016 Yanmar VIO 55 Excavator
I am starting to look for a trailer to tow my 3016. Does anyone happen to know the weight with a FEL and backhoe mounted?
   / 3016 Weight With FEL and Backhoe #2
According to Tractordata about 4500 for everything. The bare tractor weighs 2459 for the HST, and another 1230 for the backhoe, and loader is 780. Loaded tires would make a difference as well, up to 250lbs each.
Thanks for the info....would you recommend a trailer with a 5000 lb capacity, or would it be safer purchasing a 7000 lb trailer?
   / 3016 Weight With FEL and Backhoe #4
Gotta watch out. A 5k trailer is generally 5k total on the axles. If the frame and deck weighs more than 500lbs, you'd be overloaded. I'd personally get a larger trailer than is required "by the numbers".
Thanks again....I appreciate you posting the answers to my questions!!
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
2000 Freightliner FL70 Manitex 14 Ton Crane Truck (A50323)
2000 Freightliner...
2014 Nissan NV200 Cargo Van (A50323)
2014 Nissan NV200...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
