3016 HST 50 hour service
/ 3016 HST 50 hour service #1
dnelson60
Humble, TX
Mahindra 3016 HST with ML115 SKC FEL
I was starting the process of getting all the needed parts and fluids for my upcoming 50 hour service. I went thru the owner's manual for all of the required fluids and filters. I was on the last item (hydraulic fluid) when I notice the manual says to only change the engine oil and filter at 50 hours and the wait until 100 hours for the rest of the fluids.
My questions are:
1) does anyone else's manual state the same thing (question more for CUT HST owners)?:confused:
2) would it be wise to go ahead and change the hydraulic fluid and filters at 50 hours with the rest or would I just be wasting $$$ ?:confused2:
Any help or recommendations would be welcome as this is my first tractor.
David
/ 3016 HST 50 hour service #2
Being the first change is probably the most important, I would change the hyd fluid and filters at 50, but I wouldn't loose any sleep over it if you wait until 100 hrs.
That is kind of what I was thinking as well. That way I could also get all the fluids and filters on the same change basis of 100 hours marks.
Some are 100, some 200 and some 300. I think in the long run, it will help me remember to do all of the required maintenance.
Thank you for your input.
David
