3016 First full hydro change at 100 hours
   / 3016 First full hydro change at 100 hours #1
oldpilgrim
Elite Member
SE Ma
2014 Mahindra 3016HST
I really wasn't looking forward to this, other than a learning experience as how to do it best.
Mistake #1: buying hydro fluid in 5 gal pails. Next time they will all be 2 gallon jugs....it'll cost more but the trouble will be less. Either holding 5 gallon bucket to pour it into a funnel in a small hole or holding a 5 gallon bucket over a funnel transferring it into 2 gallon jugs = not fun and very messy.
Mistake # 2: under estimating the slippery mess. I've changed the oil in all my vehciles for well over 50 years and this is the slickest, messiest stuff I've ever had to work with. Make sure you have PLENTY of shop rags. I use the blue throw away paper ones.
Best thing I did: drive the rear wheels up metal ramps to get the rear end about 10-12 inches higher off the floor. I was able to put 2 empty 5 gallon buckets under the rear end and drain right into them. Lots less mess than transferring from a typical drain pan into something else. I caught nearly 9 gallons this way with very little dripping on the floor.
After getting the buckets in place, pull the plug on each gear housing. A lot will come out of these holes. Then move one of the buckets under the center drain plug and let it drain. You'll get about 8 gallons in your buckets. The manual says the tranny holds 36 qts (9 gals) in one section and another section says 10.4 gallons...go figure.
Unlike many posts, my hydro filters came off no harder than a car filter with a regular metal band filter wrench. The horizontally mounted one under the left floor came off very easy and drained another couple of qts into a pan I had in place. The vertically mounted filter under the 3pt lever on the right unscrewed just about as easy but was not easy to remove once unscrewed. Removal is blocked by the fel/bh frame and while trying to find a path out of there, all the fluid gets dumped and spreads everywhere over the frame work and hoses that are under there. I finally found a path out pushing it towards the wheel and over some hoses. Now I know, it won't be so hard the next time. It's still going to be very messy.
After changing the filters and replacing all the drain plus, refilling is a chore. The hole on the floor in front of the seat isn't very big and the 3pto drop control knob is sorta in the way, so I removed the knob and shaft which made things easier, but not by much.
I used a metal funnel with a long flexible spout and used a bungee cord to hold it upright. I had 2 2gal jugs of fluid (I used Travelers Premium) and slowly dumped them into the funnel... 4 gals to go along with the 5 gal pail I still had. Then I tried pouring from the 5 gal bucket.....you don't do it this way. :(
So I poured the 5 gal bucket into the 2 gal containers and finished up that way...put the 3pt knob/shaft back on and started the engine, let the filters fill. FEL/3pt worked well, it moved frontwards and backwards... everything worked well, checked the fluid but it's almost clear so it's real hard to tell if it was up high enough. I'll check it again later after I run it a bit.
Next was the front end. I drained the center drain and the 2 outer drains like the manual says. It must be on level ground. Replaced the plugs, opened the fill on the top right of the axle, and the over flow plugs, one on the back of each side of the axle above the drain holes previously used.
The manual say add fluid until it comes out the overflow holes. This is not going to happen.
Problem:
The fill hole is actually a little lower than the overflow holes. Manual says it holds 4.2 qts, so I put in the 4.2 qts and the fill hole was full to overflowing but nothing was coming out of the overflow holes. I'll drive it around a bit, see if the oil works over to that area by checking to see if any fluid comes out the drain holes.
If not, I'll try to dump some fluid in the overflow holes. I'm assuming that the drive gears will push enough over the to do the job, but who knows.
Has anyone else experienced this ???
So I got it done. Not real easy, but very messy. I did the engine last week.
At least I won't have to do the fluids again for a long time.
BTW, the fluids looked very clean and very clear as it was draining out, but when it hit the buckets and started accumulating, it was very dark and dirty looking.
I'm glad I did it.
I guess I got off easy with the filter change, but I'd like to know about the front axle issue.
It's something anyone can do if they have a concrete floor and don't mind some oil spots on it.
   / 3016 First full hydro change at 100 hours #2
Re: 3016 FIrst full hydro change at 100 hours
I bought a bucket pump to use on the 5 gal. containers. For me it has been the easiest way to fill the transmission. When I only need to add a small amount of fluid I use a funnel with a long extension hose.
5 Gallon Oil Pump
I'll look for a pump like that.
Regarding the fuel filter:
The manual says unscrew bowl, but I couldn't find any fuel line shut off. So I figured I'd put a bucket under it and hope for a fast change.
Surprise ! The bowl filter housing has a shut off valve inside so when the bowl is removed, it shuts off the fuel to the bowl ! Replace the bowl and it fills automatically. No wonder it doesn't need to be bled of air like other makes. Very slick engineering.
A warning to you guys who haven't done this yet, don't forget to take the little o ring out of the center of the old filter and use it in the new filter....very easy to miss....you need to reuse the outside o ring as well.
I checked the oil in the front axle and found it did indeed get into the ends of the axle. It wouldn't come out the vent holes like the manual says but it did get out where it needs to be.
So just fill the hole to the top making sure you get about 4 qts into it and you're good to go.
I greased all the points to grease and am good to go for a while, but I'd still like to be able to grease the treadle shaft.....:confused:
   / 3016 First full hydro change at 100 hours #4
The vent holes are not your oil level line. They are just vents to let the air out as you fill. Oil should be half way covering axle when you look in the fill hole..
The manual says to fill it until it comes out the holes. They are not really vent holes as they normally have a bolt in there plugging them, but none the less, that's what the manual says.
   / 3016 First full hydro change at 100 hours #6
Remember these Manuels are written in Korean or Japanese and translated. Ive found lots of errors over the years servicing these tractors. Mahindra is working to improve and update both service and operators manuels.
   / 3016 First full hydro change at 100 hours #7
Wondering if you lift the front end with the loader and tilt the axle so oil can run in the way you want it to go just a thought .
Sent from my iPhone using TractorByNet
   / 3016 First full hydro change at 100 hours #8
+1 on the bucket pump! Another slick idea is with a drill pump.
Oh.. and don't ask me how I know about that damned o-ring on the fuel filter!
Negative, the manual specifies on a level surface and there is a plugged 'vent hole' on each side of the axle. Tipping it one way or the other would simply move the fluid from one side of the axle to the other.
   / 3016 First full hydro change at 100 hours #10
I must of misunderstude what I was reading maybe lifting machine up all 4 just a bit with stablizers and bucket started it and run it in 4 wheel drive to spread it thru slowly of course
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A52748)
2017 Ford F550...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
Adams 8 Ton Weigh Hopper (A52748)
Adams 8 Ton Weigh...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A52748)
2019 Ford F550...
