3015H Grinding noise?
   / 3015H Grinding noise? #1
branson3015
Jonesboro, AR
Branson 3015
I have a 3015 and was wondering if anyone else has experienced a grinding type sound when taking off in high (C) range. This is not the gear whine but a deeper, short lived uhhhh sound that occurs on clutch release. Always in C range, sometimes in B range with a load and never in A range. Sorta like a bearing or bushing that has play maybe? I am told itsエ a common sound, maybe due to differential lock, but feel the need to ask around a bit. Thanks!
   / 3015H Grinding noise? #2
The diff lock should not make any noise when you don't have your foot on the pedal. If you try to engage it when one wheel is slipping it can make noise as it's engaging. (BTW you're not supposed to do that).
   / 3015H Grinding noise? #3
Do you have a 3015R or 3015H? H= Hydrostatic transmission. R= Gear drive.
With the H model, you don't have a clutch, nor a clutch pedal.
Sorry. Mistype. It is an è¿*? auto fill plugged in the h on google eatlier guess I transposed it.
I have no idea what痴 up with the symbols. The tractor is an R.
   / 3015H Grinding noise? #6
Do you still get the noise coming off the clutch at idle or lower RPM setting? Is the noise after your foot off the clutch pedal or as you are releasing?
It occurs as I am releasing the clutch. Apparently it痴 not that common of a noise... I am told it痴 a sound common to the 15 series.
   / 3015H Grinding noise? #8
Try it at idle or just above idle and see if it is better.
   / 3015H Grinding noise? #9
I have this video of my tractor going on the road in high range. Can you tell if the noise is also on mine?
Year: 2017 Make: Ford Model: F-550 Vehicle Type: Truck Mileage: Plate: Body Type: Regular Cab Trim (A51692)
Year: 2017 Make...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2007 FREIGHTLINER M2 BOX TRUCK (A53426)
2007 FREIGHTLINER...
MAH QUICK ATTACH MAST W/ 48" FORKS (A51246)
MAH QUICK ATTACH...
