3010 access pto switch
   / 3010 access pto switch #1
botaylorndn
Have a 3010 and I have had this happen to me before. Tractor would not start so I tinkered and cussed for several hours. Then got online and believe got my answer here. Jiggle pto handle and sure enough it cranked right up. Now it has happened again. Now jiggling does not work. Heard there is a switch in the body of my kubota. Can't really access. Do I need to take fenders off to access. I am not much of a handy man any advice is appreciated. Thank you.
   / 3010 access pto switch #2
JD 3010 doesn't have a pto safety switch but it does have a neutral start switch(parts key #28A or 28B) under cowl by trans gear shift lever.
   / 3010 access pto switch #3
I have an L3010. I'll take a look in the morning and see if I can maybe help you out some.
   / 3010 access pto switch #4
Disregard my reply as I didn't read(comprehend) the part that stated KUBOTA. Duh
   / 3010 access pto switch #5
The switch is right under the grey cover plate where your PTO lever is. It is at the PTO engaged end. So if you do any "wiggling" do it with the lever in the engaged position. Maybe frozen ???
To get access to the switch remove the grey cover. There are 4 bolts behind the tire on the upper fender area that hold it on ( I think. )
Be careful lifting the plate. Looks like the switch wires and PTO cable may be attached.
Good luck. let us know how you make out.
gg
EDIT: CHECK CORRECTION BELOW>
   / 3010 access pto switch #6
OPPS - Slight correction needed. Sorry.
gg
2007 Mauldin MT-500 T/A Tack Trailer (A49461)
2007 Mauldin...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
TEST BID LOT (A50774)
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
