Loader 300CX Loader John Deere 4400 tractor
   / 300CX Loader John Deere 4400 tractor #1
bramleyestate
Hi I have recently purchased a JD 4400 Tractor 900hrs with 300cx 4in1 loader fitted. This uses the electric button on the loader lever to operate the 4in1. When I push the lever to the right a little it opens the bucket, if I continue to push to the right it then annoyingly closers the bucket. I would like to know if this is how JD have set it up, or whether as I suspect another issue? The bucket closes properly if I move the lever to the left. Of note I am sure on a couple of occasions it did work correctly. I have noticed that when I curl the loader bucket pushing the lever to the right again, it appears to temporarily stop at the the same point I am having the 4in1 bucket change direction! Also experiencing heavy power steering at low - middle RPM??
I look forward to your replies, many thanks Jules
   / 300CX Loader John Deere 4400 tractor #2
Welcome to TBN.
When you push the loader lever all the way to the right you are going into regen mode. A designed feature to remove hydraulic pressure. It can empty a full bucket quicker. Just don't push it all the way over if you don't want that. Usually takes a bit to get used to it.
Wow great response, thanks very much. I could do with a manual I think! Any ideas on the power steering being heavy?
Thanks Jules
   / 300CX Loader John Deere 4400 tractor #4
   / 300CX Loader John Deere 4400 tractor #5
I'll let others with 4400's give their experiences. All I can say is the steering operates from a hydraulic pump. The steering will always work best when the pump is running at normal operating RPM. You may not have a problem if it works OK then.
Also, check the pressure in the front tires.
I have a 4400 and normally operate at 1500 RPM (unless running a PTO driven implement). Even at 1500 RPM, the steering is easy.
Thanks, I have checked the tyre pressures and they are correct. I have just lifted the front wheels off the ground and still the steering is hard to turn, unless i increase the rpm to 2000+. Is there a filter for the power steering? I have tried switching the engine off and turning the steering whilst in the air and it turns very lumpy whilst making an on/off suction type noise, not sure if this is what would be expected? I am thinking of chaning the hydraulic oil and filter, but not sure if this will correct or have any effect on my power steering?
On another note I have moved the regeneration lever to the middle position and now my 4in1 loader works hpw i would like it to, thats just in and out by moving the lever left or right, so thanks very much for sending me the manual link.
All the best Jules
   / 300CX Loader John Deere 4400 tractor #7
Do a search for the term "regen" for hours of reading;)
   / 300CX Loader John Deere 4400 tractor #8
Thanks, I have checked the tyre pressures and they are correct. I have just lifted the front wheels off the ground and still the steering is hard to turn, unless i increase the rpm to 2000+. Is there a filter for the power steering? I have tried switching the engine off and turning the steering whilst in the air and it turns very lumpy whilst making an on/off suction type noise...
At this point, it might be a good idea to replace both the hydraulic fluid and filters.
If the steering is still difficult after that, jack the front end up (use jack stands!!!!!) and watch the steering cylinder while another person moves the steering wheel. Look for any kind of binding. If no binding, and the fluids/filters are fresh, I'd say you have a restriction in the pump or lines. Another possibility is whoever installed that 300cx loader (they weren't around when the 4400 was manufactured) screwed up (meaning using too small an inside diameter on the hydraulic lines).
BTW, have you tried running the tractor with the loader dismounted?
   / 300CX Loader John Deere 4400 tractor #9
Not a chance...the PS system is completely separate from the rest of the system except for the common sump.
   / 300CX Loader John Deere 4400 tractor #10
Turning the wheel with the engine off won't tell you anything meaningful,
IMO.
Since the tractor is new to you, looking at the main suction filter would
be a good thing, even if you do not change the oil. This is the steel mesh
filter under the main gearbox. If it is clogged, it sure could cause havoc
with the steering.
It also could be a hardline is dented or crushed (left side of engine subframe)
or a bent rod on your steering cylinder. The old style PS cylinder has
a larger diameter than the newer (single-sided) cylinder. I have both and
the newer one looks very vulnerable.
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
Deere 335P (A53317)
Deere 335P (A53317)
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2017 FREIGHTLINER...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
JCT 72" Skid Steer Rotary Brush Cutter, Asset# 68 (A59076)
JCT 72" Skid Steer...
2014 Chevrolet Impala LT Sedan (A56859)
2014 Chevrolet...
