300cx Loader - How Loose is Too Loose
   / 300cx Loader - How Loose is Too Loose #11
Hmm.. maybe I could swap you --- my FEL for your cab?? :) This time of year; that sounds like a real good deal to me!!
On my old tractor, I thought about fabbing a setup like the Kubota, too. With the cross-brace between the loader masts.
But, I couldn't get the hood to open, then. I think it might cause a problem with your cab, too.
Is everything square? Bucket level on the ground? Does one side lift before the other arm does? (If the dealer did everything right -- these questions should be easy.)
With only 75 hrs.; maybe you're just expecting more from the loader than the FEL was designed to be...
AKfish
   / 300cx Loader - How Loose is Too Loose #12
Mine is loose like that too. I am not happy with it either. I was thinking about the cross bar too. It has a couple holes in the casting at the top of the masts. It would be easy to bolt a piece of angle across it. Anybody think the casting might break?
   / 300cx Loader - How Loose is Too Loose #13
I don't think the casting would break easily but I don't know what you'd gain bracing it for lateral movement, I thought the problem was movement fore and aft?
I've got a 300cx on my 4310, orig my tractor came with the 430 loader I swapped with a dealer for the newer model. You'd think if anyone was going to have a prob it would be with the one that was set up in my back yard, as opposed to the dealers shop or at the factory but I haven't noticed any movement and I mainly use my tractor as a loader (ie; no field work)
It would bother me to, I'd find some way to stiffen it up. Maybe some kinda shim up front where it engages the weight bracket?
   / 300cx Loader - How Loose is Too Loose #14
Sorry, just reread the OP and I see the movement referred to as inward and outward. since that's the case then a brace across the top should take care of it nicely, if hood clearance is an issue you could have a simple quick disconnect pin on one side and swing it up out of the way hinging on the other side.
I'm gonna look closer at mine since I do lift capacity loads often.
Good luck.
   / 300cx Loader - How Loose is Too Loose #15
Dave, I had the same issue with the open station 3720 with the 300cx. On that one there were 2 bolt on each side on a "bar" that went from the mast to the front weight bar. Someone installed the washers inbetween the 2 pieces of metal. Maybe it was supposed to be like that for a reason? But after removing them, and putting them next to the nut, it greatly increased its rigidity.
that is a help - mine is sloppy and I keep thinking "I wonder if they bolted everything right with the framing" will check out! I locked mine out of quick attach and that helped a little. I was surprised with this too spudland....
1993 JOHN DEERE 310D BACKHOE (A52705)
1993 JOHN DEERE...
PALLET OF LIGHT FIXTURES, BULBS, & MORE (A54756)
PALLET OF LIGHT...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A55788)
2012 Chevrolet...
2016 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2016 MACK ELITE...
UNUSED DIGGIT 20'X20' HEAVY DUTY ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
1996 INTERNATIONAL 4700 4X2 SEWAGE PUMP TRUCK (A54756)
1996 INTERNATIONAL...
