3005 and 4x4 round bales
   / 3005 and 4x4 round bales #1
poundingmill
Do you think my JD 3005 can move 4x4 round bales? I don't have to move them far, but I do need to do some stacking. The dealer says I can move the bales with the front bale spear attachment. I'm not sure. I've only had the tractor since June.
   / 3005 and 4x4 round bales #2
Your front end loader is limited to approx 750#, how much do the bales weigh ?
I would estimate about 800 lbs. Doesn't look like that will work, does it?
   / 3005 and 4x4 round bales #4
I think you could probably move them around if kept low and had PLENTY of rear ballast, but I don't think you are going to be able to "stack" them.
These bales aren't tall, but to store them I need to lay them on their sides and make two layers. How much ballast would I need?
   / 3005 and 4x4 round bales #6
You're gonna be overmatched; IMO. I don't believe your JD 3005 FEL will be able to lift a 750lb bale over 4ft vertically and stack them 2 high.
I say that, given the fact that the bale will extend more than 4 feet beyond the end of the loader arms. If the entire weight of the bale was at the pins on the loader arm - the FEL would most likely handle the load.
But, extend that weight out 4 feet -- and I have strong reservations that your tractor will pass the test.
And, with that amount of weight extended that far from the front of the tractor; you'll need some serious counterweight -- ballast. I'd want at least double the weight you're attempting to hoist; 1,500lbs, minimum -- and that may exceed the capacity of your 3pt.
My hayin' partner has a 2002, JD790 with the model 70 loader. He's tried workin' with big round bales to feed his 6 head of horses. He's feedin' small squares...
AKfish
I know the loader manual says not to handle round bales, yet John Deere has a compatible front loader spear on its web site and the dealer has one in stock. I guess I'll just use the 3 pt. hitch.:confused:
   / 3005 and 4x4 round bales #9
Some of the newer round balers will pump out 400lb bales. If you can find a source of the smaller bales, the spear might work out OK.
AKfish
   / 3005 and 4x4 round bales #10
I have a 790--same thing. I have also moved lots of round bales over the years with other tractors and would guess your odds of success with any round bale and a 3005 are zero. The other guys are right.
2004 Ford F-250 (A53422)
2004 Ford F-250...
Ford 600 Tractor (RUNS) (A50775)
Ford 600 Tractor...
UNUSED LANDHONOR FW-13-15000G HYD WINCH (A54757)
UNUSED LANDHONOR...
UNUSED TOY REMOTE CONTROLLED CEMENT TRUCK (A54756)
UNUSED TOY REMOTE...
CAT Skid Steer (A50322)
CAT Skid Steer...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
