300 Hour Service
   / 300 Hour Service #1
SteveInMD
Platinum Member
Brookeville, MD
TC33D
I just did my 300 hour service on my TC33D. The manual says the tractor will take about 8.8 gallons of hydraulic fluid if it's a hydrostatic transmission. I checked the fluid level after adding about 7.5 gallons and it was already overfilled. I ran it a bit and worked the 3 point hitch and loader, but the level was still too high. I ended up draining out some fluid to get near to the correct range. My question is, did I do something wrong? Also, what would happen if I had left it overfilled?
   / 300 Hour Service #2
I had a similar situation with my TC35D. I ended up draining out the excess.
   / 300 Hour Service #3
Steve how many drain points did you use to drain the old oil? My TC-40D had 2 different drains to dump all the hydraulic oil.
   / 300 Hour Service #4
Pineridge probably has the answer. A TN has a number of drain plugs.
But even then you will not get all the fluid out.
Kind of like an oil change or a tranny fluid swap on a truck or car. Some of the oil will still remain in side the machine stuck to the walls, and inner workings.
Its a good idea to fill it back up with say 75-80% of the "capacity", and then check the level. You can then top off as needed.
Fred
   / 300 Hour Service
I drained the oil from three points. I think that is all of plugs a TC33D has.
   / 300 Hour Service #6
Here are some possibilities for additional trapped oil as Phred suggested:
1. hydrostatic transmission
2. hydrostatic and hydraulic filters
3. hydraulic pump
4. hydraulic oil cooler
5. lift cylinder
6. loader
7. wet brake assy/housing
I don't know if you changed both filters when you changed the oil, but all those other points would have some trapped fluid. A gallon is a lot. Also, did you check the level before draining all the oil?
Next time, you'll know to watch it. Nuthin' like experience as a great teacher. /forums/images/graemlins/crazy.gif
In a hydraulic oil reservoir, an extra couple of quarts won't make much difference, but if the tractor were old and had poor axle seals, you could see some leakage. I'd take the oil out just as you did, but I doubt you'd see any negative effects on your tractor. /forums/images/graemlins/smile.gif
   / 300 Hour Service #7
I had the same issue on my TC40D. It overfilled by the equivalent of the "hashmark" area of the dipstick. I left it in. It kind of "cured" itself 50 hours later when I added a hydraulic top link. I guess the hoses and cylinder hold the volume of my overfill. No problems or leaks occured before then.
Mark
   / 300 Hour Service #8
Personally I think that's how New Holland gets us all to buy a little extra hydraulic oil. /forums/images/graemlins/smirk.gif It's good business for them, no?
   / 300 Hour Service #9
</font><font color="blue" class="small">( Personally I think that's how New Holland gets us all to buy a little extra hydraulic oil. /forums/images/graemlins/smirk.gif It's good business for them, no? )</font>
I think you are right, Pineridge. But I draw the line when they try to sell me 1-1/2 filters. /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
2000 FORD E350 CUTAWAY BOX TRUCK (A52577)
2000 FORD E350...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
