3 year old (300 hours) L4610 hard to start
   / 3 year old (300 hours) L4610 hard to start #1
jedens
La Veta, CO
Kubota 4610
For the first time my L4610 has been hard to start. When this happened my first instinct was to find the choke and use it. I can't find it so I'm assuming that it must have an automatic choke. I've had it serviced regularly by a kubota dealer. Any thoughts on why it is getting hard to start?
   / 3 year old (300 hours) L4610 hard to start #2
Joe, diesel engines don't have a choke. I assume that model has glow plugs. Are you using them? If not, or perhaps even if you are, colder temperatures might make a difference; takes longer on the glow plugs. Have you checked to make sure the fuel filter isn't partially stopped up reducing fuel flow? Is the air cleaner clean? And does it seem to run properly after it starts?
   / 3 year old (300 hours) L4610 hard to start #3
Joe, My L4610 has a light on the dash indicating the heaters are on. After turning on the ignition, are you waiting for the light to go out before engaging the starter?
Have you cleaned & changed the fuel filter as per schedule? My fuel filter bowl is normally a mess, each time I service it, & I don't really understand why. I also have a fuel filter on my tank pump.
   / 3 year old (300 hours) L4610 hard to start #4
</font><font color="blue" class="small">( Have you cleaned & changed the fuel filter as per schedule? My fuel filter bowl is normally a mess, each time I service it, & I don't really understand why. I also have a fuel filter on my tank pump. )</font>
Sure you aren't raising little critters in your diesel tank (bacteria or whatever that stuff that grows in diesel)? Sounds like you have your own storage tank and you may be raising more critters on that farm than you are aware of.
bill Tolle
   / 3 year old (300 hours) L4610 hard to start #5
If that is possible, can someone tell me how to determine if I am rasing these diesel critters as well as how to get rid of them?
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A52128)
2009 Freightliner...
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
CATERPILLAR D3K2...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
