tradosaurus
Super Member
- Joined
- May 8, 2017
- Messages
- 5,972
- Location
- Texarkana, TX
- Tractor
- Kubota MX5400 HST, heavy duty bucket, 3rd function, R1 tires (rears filled), 2 remotes
Went to use my rotary cutter and the 3 point won't raise and lower it. I checked the adjustment dial under the seat that controls the pressure of the 3 pt hitch. That didn't work.
I saw a dark puddle on the ground under the "passenger" side of the tractor where the hydraulic valve is located.
The nut was loose on one of the hoses so tightened it. The hydraulic oil filter is bent to **** where I must have hit a stump. It's not leaking but looks like a soda can was crushed.
I'm going to replace the filter as I'm assuming it is restricting flow and then replace the fluid that I lost. I have to wait until Monday to get the filter.
Hopefully this will fix it.
I'm really amazed that this filter isn't protect with a skid plate.
