3 pt with down pressure
   / 3 pt with down pressure #11
Have you thought about getting some 1/2" steel sheets cut the appropriate size and welding to the box blade? I was reading in a thread somewhere here where someone suggested this to add weight to their box blade.
You may be able to strap several pieces on top and weld a few pieces on the back, as well as adding pieces to the sides... obviously you have to want them to be there permanently.
I know Tufline has the option of 1/4" sides or 1/2" sides on some of their box blades and the extra 1/4" adds ~75lbs total weight.
What's the normal size of sides? 12" X 12" or so... you have a 6' BB so adding 1/4" to the sides and back could add as much as 300lbs. Does that sound right? I don't know how much steel weighs but I'm sure someone here can tell ya.
   / 3 pt with down pressure #12
varies depending on the grade.....but a ballpark would be:
41# for one square foot @ 1" thickness
   / 3 pt with down pressure #13
Hmmm.... that would mean at 37.5lbs per side on the Tufline with only a 1/4" that it is obviously larger than 12" X 12" sides. Those sides would have to be pretty large because it would take what... 24" X 24" at 1/4" to make a sq. ft. of 1"... am I figuring that right?
Makes me curious as to how they come up with 37.5lbs per side. They must be adding some somewhere else as well.
   / 3 pt with down pressure #14
Got me wondering as well and questioning my memory (you know - 2nd thing to go <g>) on density of steel plate. 490-495 #/CF so the 41 #/SF/In is pretty close http://www.reade.com/Particle_Briefings/spec_gra2.html
Your calculations are OTM 12x12x1=144=24x24x.25
Can't help with the riddle on exactly how they come up with their figures though...sorry
   / 3 pt with down pressure #15
They just about have to be adding some more metal somewhere other than the sides because I don't think their sides are 4 sq. ft. in area on each side.
I'll probably go with the TB384 anyway... it weighs 1138lbs.
I considered the Woods XB84 but I understand it cost around $1600 or so. OUCH!
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
2015 CATERPILLAR 745C 6X6 OFF ROAD DUMP TRUCK (A51242)
2015 CATERPILLAR...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
