3 pt with down pressure
   / 3 pt with down pressure #1
Tkirkland
missouri
Is there anyway to get down pressure on 3pt implements? Our soil is pretty rocky and my 6' BB just skips over the rocks. I have added weight to the BB and that helps some but not quite enough.
Also, has anybody ever used a hydraulic cylinder as the top link so that you can angle the blades on the fly?
   / 3 pt with down pressure #2
Tkirkland
As far I am aware Belarus was the only tractor I new of that had down pressure and that type of down pressure would not work for what you are trying to do. Do you have the speed valve set all the way open so your 3 pt can move (up or down) as fast as possible.
Happy Tractoring
Chipperman /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
   / 3 pt with down pressure #3
Like chipperman said, I'm afraid.
You're pretty much stuck with making use of the scarifiers and/or shortening the top link some to get a more agressive angle on the cutting edge. Also, if your BB has a rigid rear-most blade, you can remove it so it doesn't interfere with the front blade.
   / 3 pt with down pressure #4
The rest have said all that can be said about the down pressure. There are a couple of companies that make a hydraulic top link. I am not shure who at the moment, but I have seen them advertised. If I find out who, I will reply again.
GLaWall
Your Mahindra Tractor Dealer
Batavia, NY
   / 3 pt with down pressure #5
look in the customization or attachment areas on this site for a "top n tilt" setup. Also, there are downpressure kits they make for posthole diggers, don't know if you could modify them to work. My dad has a IH 560 that has a 2point fast hitch. When we attached the 3 point kit and put some pins in the fast hitch to stiffen it, it gave it downpressure. Don't think you'd go out and buy an old tractor and a kit just so you had downpressure though /forums/images/graemlins/smile.gif.
Thanks to all that posted... I think I'll just pile more rocks on top of the BB to add weight... and get the added benefit of increased FEL stability!
   / 3 pt with down pressure #7
Replace you lift rods with hydraulic cylinders, raise the rock shaft all the way up and use the cylinders to put down pressure on the implement. This puts a lot of stress on everything and will break something sooner or later.
   / 3 pt with down pressure #8
Out of curiousity:
Are your scarifier shanks able to dig into your dirt/rocks?
Are you trying to grade solid rock?
How fast are you driving the tractor?
Do you have a box blade with a fixed rear blade?
Have you adjusted your top link?
Do you have a box blade with tapered sides (thus reveiling more of the scarifiers)?
I think there are some of us here that would like to help that have had the same original question as you. I, for one, have concluded that I could, theoretically, pile my house on my BB and get no better results without adjusting something other than weight.
Cheers!
HomeBrew2
Yep, the shanks can dig up some of the rocks... trouble is I have soooo many. Probably about 50-50 rock/soil in some areas.
I usually go very slow when blading on the rocks. It seems to help.
Yes, my rear blade is fixed.
I do find that the blade will move rocks better with some weight on it.. regardless of top link position.. going forward or backward etc...
   / 3 pt with down pressure #10
Sounds like you're getting it. I don't have near as many rocks as you but really hard packed clay. Sometimes it takes me half a dozen passes of chiseling with the shanks just to penetrate a short area. Once I break thru and get some slots established, I start doing a zig zag pattern to break up the areas between the shank slots ... that's about when I can get some real grading done. Good luck with it.
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52128)
DeeZee Crossover...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
UNUSED FUTURE SKID STEER QUICK ATTACH LAND LEVELER (A51244)
UNUSED FUTURE SKID...
John Deere 1770 Conservation 16 Row Planter (A50774)
John Deere 1770...
197711 (A51244)
197711 (A51244)
