3 pt. Trailer Hitch and Tool Racks
   / 3 pt. Trailer Hitch and Tool Racks #1
ETpilot
East Texas
Thought I would post pictures of my 3 pt trailer hitch and trailer tool racks. The hitch I made years ago when I first started welding. It had a couple of issues I decided to fix. One the lower ball flat stock had bent down with use as I did not support it enough. I straightened the flat stock and added side gussets. It should be ok now. Second I had flat stock below the upper ball on a 45* to the pipe. The problem here was that I have a trailer that has the latch where you lift a handle to release. This handle always kept getting hung up with the flat stock. I had to use care moving that trailer. I removed the flat stock and added the angle iron support. This should work. I, also, got rid of the crummy ball that it had and installed a new lower 2 ball. I can move all my trailers including the goosenecks with this hitch. I may paint it one day.
One of the members on another forum posed a question about trailer tool racks. One day I was using my trailer for collecting firewood, and had all my tools in the trailer. I thought of that question and thought it was a good idea. So, I made these tool racks to carry the tools I may need. I was going to bend the rod into a right angle but changed my mind and made it a T joint. That way I can use bungee cord below and above the cross member to hold the tools. I believe it should work good. . I am going to make a folding rest for the power head on the pole saw. It will ride better that way. When not in use the racks rotate out of the way. I covered the rod with clear plastic tubing for tool protection. No telling what I may be carrying. On the other side of the trailer I am thinking of adding a folding shelf. I would use it to carry the chainsaw, fuel, oil. Etc.
   / 3 pt. Trailer Hitch and Tool Racks #2
Great idea, ET.
I need to copy your idea for my lawn trailer. I have the same problem, my trimmer winds up underneath the branches. The hitch looks like it does the job very well.
Thanks for sharing.
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
PAIR OF 5' CLIP ON TRAILER RAMPS (A51247)
PAIR OF 5' CLIP ON...
2025 CFG Industrial QH12R (A50123)
2025 CFG...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
2007 VOLVO VHD64 TRI AXLE DUMP TRUCK (A53426)
2007 VOLVO VHD64...
