3-pt stuck or jammed in up position
   / 3-pt stuck or jammed in up position #1
IndiantownFla
SE Fla
Kubota L3830 GST
hello, my box blade hung me up on the edge of a dirt bank and i used my fel to work loose, but it looks like in the process i jammed the 3-pt in the up position, i,ve put weight on it & tried to "bump" it loose. i don't see that anything has come undone in the hydraulics. has anyone had this happen to them or does anyone have any ideas how to lower it.
thanks for your help
   / 3-pt stuck or jammed in up position #2
What kind of tractor do you have? Most of the time that's happened, it's been because the valve that regulates the speed with which the 3-point lowers was closed. Do you have a knob in front of the seat that adjusts that speed? If so, turn it counterclockwise and see if it lowers. If not, sorry I wasn't more help.
   / 3-pt stuck or jammed in up position #3
I don't have 1st hand knowledge of this but have seen some posts on the subject. They say it happens when the 3ph lift is lifted, by outside forces, higher than the hydraulics can lift it, and pulls a piston out of its cylinder. You have to remove the top plate of the 3ph mech. and guide the piston back into the cylinder by hand.
2025 REDELIFT CPD25-XD4 FORKLIFT (A52576)
2025 REDELIFT...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53472)
2006 Magnolia Dry...
2020 Mclanahan 150 TPH USP Wash Plant (A52377)
2020 Mclanahan 150...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
City of Buckhannon - 2005 Volvo Garbage Truck (A52384)
City of Buckhannon...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
