3 pt rollers - do they work?
/ 3 pt rollers - do they work? #1
RSR
Platinum Member
North Country, NY
LS XR4145HC
I have 3/4- crushed stone on my driveway and the private road I'm on. Whenever bringing in gravel, or regrading the existing, if I can pack it down well, it locks together and gives a nice flat smooth surface.
To get there, though, it requires repeatedly driving a car back and forth, back and forth, ad nauseum.
So my question is, how do 3 pt rollers work for packing down gravel roads? The heaviest one I can find is a 6 foot wide one that is about 1,400 lbs. Comparing the weight, and area of contact with the road, the amount of pressure (Force/Area) it can generate doesn't seem like much of an improvement, if any, over the pressure from car tires driving back and forth. The only unknown is the rigid drum should create a bit more of a point (or line) of contact in comparison to a car tires, and therefore may generate significantly more pressure depending on the area of the contact patch with the gravel.
Does anyone have any practical experience using one of these?
/ 3 pt rollers - do they work? #2
No experience - practical or otherwise. Go to Google, upper right corner. Enter earth roller, compactor, home-made rollers/compactor. About a year ago there was an excellent thread about home-made rollers. One in particular caught my attention - welded frame, concrete weights for weight, standard auto tires were what it rolled on. Looked like it could be made to accommodate almost any weight.
Unfortunately - I'm in the same boat as you. Back/forth with my tractor.
/ 3 pt rollers - do they work? #3
Anything that doesn’t vibrate would take enormous weight to do the job. Keep using vehicles or the tractor to roll it with the wheels.
/ 3 pt rollers - do they work? #4
I have thought about getting an axle out of a trailer (tractor trailer type) narrowing it and adding a third wheel to each side then adding a mafia block for weight.
Tire will do a better job of compacting then a steel drum as the gravel will get pushed sideways as well as down.
This would be for drawbar pulling, a 3 point would not work well if any turns where involved.
or this;
PT13 & PT15 Pull-Type Pneumatic Tire Rollers From: WRT Equipment | For Construction Pros
or even nicer; a bit hard to justify the cost,
New Rubber tire road roller/ 26 tons pneumatic roller/road roller RP26 with certificate of Road Roller - guangzhoudaikun
/ 3 pt rollers - do they work? #5
Rent a small roller, prob has vibrate feature. One pass equals twenty with the car.
/ 3 pt rollers - do they work? #6
I bought a little roller for packing dirt. It does a good job but it’s slow. IMG_9060.JPG
/ 3 pt rollers - do they work? #7
You can rent a 1.5 ton roller with vibe for under 200.00 for the day.....
I'm guessing by the lack of responses of those going this route for compacting a gravel road, it's not a very useful approach.
It looks like the answer is "just keep driving over it with a car".
It's not important enough to bother with the hassle and cost of renting, and as interesting as a dedicated wagon roller is, I really don't have the skills or time or space to fab something up like that and store it.
/ 3 pt rollers - do they work? #10
It is the most practical some times.
Besides which you didn't mention if your driveway was flat or steep,
I have seen several of the smaller rollers slid off the roads when they have been preping them for paving.
/ 3 pt rollers - do they work? #11
I've got a couple of those 24" compactors. The type with an engine and centrifugal clutch driving a counter weight. Heavier than heck but move by themselves when powered up. I've given thought to adapting those to a three point hitch for my dirt driveway. Just haven't got a roundtoit yet. In the meantime, I run back and forth with my little dozer. It has flat street cleats so it works pretty well. Another reason to not spend time building something that will be slow and narrow. Unless I run across another compactor or two, I'll stick with the dozer. ;)
The thought of a PTO driven gang of compactors crossed my mind--In a blur. :laughing:
2022 ALLIANCE NORTH AMERICA AIR MAN SDG 25 GENERATOR (A65643)
2022 ALLIANCE...
2006 VOLVO VNL (A65643)
2006 VOLVO VNL...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
