tjones59
Not sure if this is the right forum. If not hopefully someone can point me to it.
I have a 1959 MF 50 that I bought last year. The guy never used any attachments on it just the loader. I have a JD 39N sickle bar I mow around my pond with. My old Ford 861 powermaster had no problems lifting and mowing with this attached. When I hook it to the MF 50 it won't lift it high enough for the blade end to be off of the ground. I've played with the draft control but it still won't raise it all the way off the ground. The weird thing is the lift arms are only about an inch or two from being up as high as they'll go, nearly touching the top.
When I bought the tractor I stood on the lift and had him raise it. I weigh 285 so I figured it was OK. I put my 6' box blade on it which is pretty heavy and it lifts it like it's not even there. I can't imagine the sickle bar is so much heavier it can't lift it but I am probably wrong. Looking for any suggestions before I sell this MF 50 and give up buying used equipment.
