3 pt lift spec ?'s
   / 3 pt lift spec ?'s #1
twoodard04
clyde ny
in market
Morning all. While going through specs on 3 pt lifts iI see "measured 24" behind lift points" are the lift points the ball ends or where the link connects from the upper arms?
   / 3 pt lift spec ?'s #2
24" behind the lift pins or balls.
   / 3 pt lift spec ?'s #3
Take the lift ratings with a grain of salt.
They can change just based on how the toplink is set up.
And I wouldnt plan on getting a tractor that "just" meets your needs. If you are looking at lifting something that weighs 1500#, be looking at a tractor that has a pin spec of double that.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
