3 pt lift spec ?'s
   / 3 pt lift spec ?'s #1
twoodard04
clyde ny
in market
Morning all. While going through specs on 3 pt lifts iI see "measured 24" behind lift points" are the lift points the ball ends or where the link connects from the upper arms?
   / 3 pt lift spec ?'s #2
24" behind the lift pins or balls.
   / 3 pt lift spec ?'s #3
Take the lift ratings with a grain of salt.
They can change just based on how the toplink is set up.
And I wouldnt plan on getting a tractor that "just" meets your needs. If you are looking at lifting something that weighs 1500#, be looking at a tractor that has a pin spec of double that.
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
6 Pallets of Oil / Chemicals absorbing pads (A53117)
6 Pallets of Oil /...
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
