3 pt lift problem
/ 3 pt lift problem #1
MillWeld
Durham NC
Ford 641
My Ford 641 tractor lift will occasionally make very small incremental jerky lifts when I raise the lift lever. It comes and goes; I first noticed it maybe 5 years ago during cold winter but returned to normal operation after a warmup. It was not low on hydraulic fluid but I added some anyway. I have also noticed it in warm weather. It has done this only 3 - 4 times since the first observation so I have not done anything about it. Any hints as to cause and solution?
/ 3 pt lift problem #2
I would suspect a leaky valve and it might only occur randomly.
Could also be that the valve is not in the neutral position, and vibration might move it somewhat.
Does the 3tp ever slowly lift over time with no attachments. What if the 3pt valve had a 10 drop leak into the 3pt cyl, and what if the 3pt cyl has a small leak. Just thinking.
Rogator RG1300C (A63688)
Rogator RG1300C...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
2023 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2023 Posi Track...
John Deere 4040 Tractor (A64047)
John Deere 4040...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
