3 pt leaks up & control lever moves with it.
   / 3 pt leaks up & control lever moves with it. #1
North Dakota
Mandan ND
'84 Ford 1710
On my 1984 ford 1710 the 3 pt as started leaking up when I'm using it. The control lever for raising and lowering the 3 pt moves on its own as it does this. If I hold the control lever or put a stop behind it then the 3pt does not leak up any more.
What would cause the lever to move on its own and raise the 3 pt?
Loader does leak up or down. 3 pt and loader share same hydraulic pump.
   / 3 pt leaks up & control lever moves with it. #2
Could the lever need tightened up a little bit and the vibrations are actually causing the lever to move thus causing your "leak up?"
I thought about that. I'll have to look closer at the control lever. But I do not remeber seeing a place to tighten it up.
iDrive TDS-2010H...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2012 CATERPILLAR D4K LGP CRAWLER DOZER (A60429)
2012 CATERPILLAR...
