3 pt leaks up & control lever moves with it.
   / 3 pt leaks up & control lever moves with it. #1
North Dakota
Mandan ND
'84 Ford 1710
On my 1984 ford 1710 the 3 pt as started leaking up when I'm using it. The control lever for raising and lowering the 3 pt moves on its own as it does this. If I hold the control lever or put a stop behind it then the 3pt does not leak up any more.
What would cause the lever to move on its own and raise the 3 pt?
Loader does leak up or down. 3 pt and loader share same hydraulic pump.
   / 3 pt leaks up & control lever moves with it. #2
Could the lever need tightened up a little bit and the vibrations are actually causing the lever to move thus causing your "leak up?"
I thought about that. I'll have to look closer at the control lever. But I do not remeber seeing a place to tighten it up.
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
PALLET OF OIL COOLERS (A53843)
PALLET OF OIL...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
Kuhn FC 4000 RG (A50123)
Kuhn FC 4000 RG...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
