3 pt leaks up & control lever moves as well
   / 3 pt leaks up & control lever moves as well #1
North Dakota
Mandan ND
'84 Ford 1710
On my 1984 ford 1710 the 3 pt as started leaking up when I'm using it. The control lever for raising and lowering the 3 pt moves on its own as it does this. If I hold the control lever or put a stop behind it then the 3pt does not leak up any more.
What would cause the lever to move on its own and raise the 3 pt?
Loader does leak up or down. 3 pt and loader share same hydraulic pump.
   / 3 pt leaks up & control lever moves as well #2
Check to see if there is a friction disc / tension nut on that model.
I'm not up on the jap compacts ford sold...
soundguy
I'll look at the mechanism a little closer. I just do not remeber seeing a place to tighten the lever.
   / 3 pt leaks up & control lever moves as well #4
The mechanism is for sure different than the old fords.
i grabbed the diagrams from CNH.. the plain 1710 digram don't show much.. the 1710 draft control diagram has more detail.
I see some washers.. so those might be the friction control adjustment... hard to say without a master parts catalog in my hands... and i don't have one for that model.
RickB may know off the top of his head though.
soundguy
   / 3 pt leaks up & control lever moves as well #5
Looks like nut # 35 and 14 adjust washers I think that might be a place to start.
   / 3 pt leaks up & control lever moves as well #6
There is a low and high adjustment for the lever in pic 1 and 2, that should not be your problem. On pic 3 below a bracket where the main control arm rod is and #14 is where you tighten it.
JC,
Thanks guys,
JC, I believe you are talking about that larger nut that is just peeking out from behind the shield/shroud and is against the casing under the seat.
I'll try and tighten that nut when it gets a little warmer outside.
   / 3 pt leaks up & control lever moves as well #8
Thanks guys,
Yes, I did not have a better picture from the side.There are couple of washers behind the nut to adjust the friction. I don't think the nut has to be real tight , just enough for the lever to move solidly without slippage.
JC,
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
New/Unused 78in Quick Attach Grass Fork Grapple (A51573)
New/Unused 78in...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
