3 pt. leaf blower
   / 3 pt. leaf blower #1
Don87
Elite Member
SW Pa.
Massey Ferguson GC2400
I'm going to throw this out there(dunno if it has been discussed before)...........but I have a spare furnace blower............. Seems to me like it would work with a few modifications, and potentially save a person a buck or two as compared to a commercial unit.
Thoughts?
   / 3 pt. leaf blower
I was honestly considering PTO, and putting a pulley on the shaft to adjust blower speed.
   / 3 pt. leaf blower #4
How fast does a factory made leaf blower spin compared to the furnace blower's normal speed?
If you have to speed up the furnace blower, will the bearings take the added RPM?
How are you intending to funnel the airflow so it does effective blowing?
If you build it, please post plenty of pics and let us know how well it works.
   / 3 pt. leaf blower
I'll answer the first two questions at once, I think the rated speed for the furnace blower will be fine(taking for granted that one uses a large blower).(they will take the hat off your head).
The blowers that I'm accustomed to working with actually use 'bushings' instead of bearings,...........but with that said.............considering the service life of a furnace blower(with yearly oiling), seems like it might be ok.
And the last question............funneling airflow.
Furnace blowers take air in from the side, and discharge from a rectangular opening facing 90 degrees away from the 'inlet', so I see no real problem there.(but I could be wrong, that's why I'm asking for input).
Thanks for the thoughts, they are very much appreciated.
   / 3 pt. leaf blower
I could have phrased that better I think............
If mounting the the furnace blower to the PTO, the 'inlet' would face the rear of the tractor, the 'exhaust', would face the left side of the tractor. One could possibly 'funnel' the air flow down some(to better direct blowing), but I haven't experimented............it's all just a thought.
   / 3 pt. leaf blower
I think I screwed up, this thread probably should have been placed in the 'build it yourself' forum.
Mods............can we move it?
   / 3 pt. leaf blower #8
Don,
Good idea, nice project! Pulley system seems like a good way to go. I'd be a little concerned with the lightweight of the typical blower housing and make sure I had a decent sub frame for pulley mounts. I'd also want to the belts loose, to gradually build speed and slip on startup if I was gonna take the blower much past it's rated speed. That should help longevity and help make sure your tractor didn't tear it up.
Sounds like a good project.
Joe
   / 3 pt. leaf blower #9
Most pto blowers blow arround 150mph and 10,000 cfm displacement. I don't thik a furnace blower will work. It moves a large volume of air but at low velosity. I have been wanting to build on for about 2 yrs but can not find any thing that will move enough air at a reasonable price. I have been lookig at silage blowers lately wondering if they would work or if they would be to big.
Bill
1973 Pontiac Grand Prix Car (RUNS)(TITLE) (A50774)
1973 Pontiac Grand...
Kent KHB3G Q.A Hydraulic Breaker (A50121)
Kent KHB3G Q.A...
2018 JLG Skytrak 8042 8,000lbs 4x4 Rough Terrain Telehandler (A50322)
2018 JLG Skytrak...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
(4) Painter Hoppers (A50121)
(4) Painter...
