3 pt hitch
/ 3 pt hitch #1
msjanket
On the G152, does the 3 pt hitch go down by gravity or hydraulic, positive pressure? Can the hitch be moved upward by hand? Or does it take hydraulic pressure again? If using a post hole digger, if there's no pressure downward save gravity, is hole digging possible?
/ 3 pt hitch #2
The G152 3pt. goes down under the weight of the implement. there is no positive down pressure, just on the up side. If the post hole digger is heavy enough I supose it should work. I guess it would depend on what kind of soil your augering into.
Not sure exactly what your asking about bringing the 3pt. up by hand? I suppose if the hydraulics (i.e. tractor) is shut down you should be able to move the hitch up or down by hand. I would loosen the restrictor valve t- handle (under the seat) before i tired it though. Might save your back!! :D
Sakai SV505 (A60462)
3 Brake Drums (A62613)
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
