3-pt hitch rear end loader
   / 3-pt hitch rear end loader #11
I WOULD LOVE TO SEE A PIC OF THIS! OR TO BE ABLE TO BUY A REAR LOADER LIKE THE GOOD LOOKING GIRL USED IN THE MOVIE FROM THE 50'S CALLED "Holiday For Bill" that is on youtube.com. I want to use my 8n to load things into a spreader on occasion. Please post pics! or email to kw_y2k@hotmail.com Thanks!!
I made one quite some time ago in less than (2) hours by hooking the end of a 3 pt lift boom to the top link position on a pond scoop. I attached (2) lengths of heavy angle iron between the tractors lower links, and the lower attach points of the scoop. After you lift up the scoop, you pull a rope to dump it. This setup worked suprisingly well. I had it on a 2wd ford 2000 and it actually worked better than a front loader on this tractor. Having the weight over the rear drive axle allowed the tractor to dig well out of a hard pile, while it instantly lost traction with a front loader. The 2000 had plenty of hydraulic power to lift a heaping scoop of gravel or topsoil, but I used it mainly on manure, to load spreader. It would lift high enough to load a spreader, trailer or pickup truck. I even used it to load a dumptruck when the rear tires were in a ditch to lower it a bit. My old 8n could barely lift the empty scoop on the end of the boom due to a lack of hydraulic power. A couple suitcase weights on the front of the 2000 helped stabilize the rig. You can probably build one of these yourself today with a boom and scoop from TSC for around $500.
   / 3-pt hitch rear end loader #12
My neck is getting soar thinking about using it!
Mike
   / 3-pt hitch rear end loader #13
I know this is old, but it's a good topic. Here is one that raises with a hyd piston above what the 3pt lifts.
   / 3-pt hitch rear end loader #14
I made up this three-point adapter for JD hook and pin connected stuff (bucket, pallet forks). Main idea was to carry things too heavy for the loader on the back. It works, but doesn't go very high or dump, and not many things I need to lift that are that heavy. It is also heavy as all get out. Now that I have a tote to water trees with, I might start using it for that because I can't comfortably carry that thing more than about 1/3 full.
   / 3-pt hitch rear end loader #15
It makes a lot of sense placing the heavy load over the larger rear tires.
This "loader" actually has a hyd piston that lifts it higher then the 3p could ever lift it.
   / 3-pt hitch rear end loader #16
I use this 3pt to SSQA adapter to put a FEL bucket on the 3pt:
I then use the hyd. top link cylinder to pick up and dump heavy material.
It's tough to get a full bucket and the lift is limited to the 3pt height but it works for moving material around. With a bucket on the FEL and another on the 3pt, you can move twice the material in a single trip.
It also works well for rear ballast.
   / 3-pt hitch rear end loader #17
OTHER VENDORS:
2020 Hyundai Santa Fe SUV (A56859)
2020 Hyundai Santa...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
2808 (A58376)
2808 (A58376)
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58216)
2025 FUTURE X-DM43...
LOT: Dewalt Electric Sawzall, Craftsman Palm Sander (A59076)
LOT: Dewalt...
