3 pt hitch questions
   / 3 pt hitch questions #1
Indygunworks
Indianapolis, IN
1980 Ford 340
The following are a few photos of the 3 pt hitch hydraulics. Can anyone explain the two levers for me? It appears one has a detent that MIGHT hold it open, and the other doesn't. Perhaps its just a control for the two lines on either side. Is there anyway to tell which should be the positive and which should be the return? Can these run a hydraulic top link? The one line w/ the guage is what my guy used to check out the PSI output of the internal 3 pt pump and to set the pressure relief valve.
What sort of other uses would these remotes have?
Also, the top link connection is connected to a punger for the draft mode I am sure. I am familiar with the lever that switches mode, however I have not messed around w/ it in draft control at all to see if A it works and B how well, so it might be a moot point. My question though is that there is a pin under where I have the top link hooked up that appears would make the whole top link connect come unhinged "lengthening" the connection point on the tractor... it would also no doubt make the draft control plunger more sensitive... If I am runnin in draft control like w/ a grader box, or a plow (haven't tried either one of them yet though) do I need to "unpin" this point for the draft control to be effective? What other purposes might it serve?
Next question.... My implements "swing" quite freely behind the tractor, as much as a foot either direction. that makes it a pain when backing up with the bush hog and grader blade, and I am sure once I start using the grader box its going to be a HUGE pain in the you know where.... also will probably be a pain once I live on the property and use the blade to push snow in reverse with the blade angled. I have included a few photo's of what looks like a possible mounting point for a stabilizer set up... I am not really familiar with stabilizers and how the attach/adjust so if you don't mind could you take a look at these photo's and give me and idea what I am working with on a stabilizer system. Will the stabilizers tractor supply sells work? I have only looked at them and have not taken the time to figure out if they would even work for my application.
The bottom of the loader subframe w/ the mounting holes
a reference from the mounting holes to the lift arm
and an overview of the 3 pt hitch as its currently set up.
   / 3 pt hitch questions #2
I can't speak to the hydraulics question, but on the movement of the hitch it looks like you are missing your adjustable stabilizer arms. On the diagram it is pointed out on the right side, second from bottom.
There are all different kinds of setups. You might can google your model of tractor with the term "stabilizer arms" and find what you need.
that picture makes it look like they hook up to the actual hole in the ball on the 3 pt lift/ I do have a place right behind my pats easy change that's about 3/4 inch diameter and is just a loose pin being held in by roll pins on either side to keep it from falling out... Perhaps that's where the stabilizers hook up to? They say adjustable, but how do they adjust? Is that what changes the width between the two arms? So every time I put a new implement on w/ different spacing I have to get under there and adjust them to the proper width?
I called and "dave" is going to go take a look and see if they are still there and call me back with a price.
   / 3 pt hitch questions #7
One thing that I have is a rubber cord between my lift arms. It keeps the slack out of the stabilizer arms.
2022 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2022 KOMATSU...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2017 Case CX145D (A60462)
2017 Case CX145D...
Tank Only (A59076)
Tank Only (A59076)
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2018 RoGator 1100C (A56438)
2018 RoGator 1100C...
