3 pt hitch hydraulic problem
/ 3 pt hitch hydraulic problem #1
jimbull34
bobcat 335
I have a bobcat ct335 and while bushhogging this morning the 3 pt hitch just dropped the hog into the ground. I worked the speed set for the hyd. thinking that hit the slowest end with no luck. I shut it off thinking it would recycle if it were a air bubble problem, no luck. I disconnected the hog from the lift arms thinking that if I manually lift them, it might move the air, if thats the problem out of the lines, no luck, the arms just drop without any resistance at all. I checked the set screw on the raise/lower mech. no problem there, the shaft into the housing moves. oil level fine, tractor has 255 hrs on it. Never had this problem before.
Dealer is coming out monday, but does anyone have any ideas in the mean time?
2018 Chevy Traverse 3rd Row Seating (A61307)
2018 Chevy...
V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
V.E. ENTERPRISES...
Schulte SBW800 Rock Windrower (A61307)
Schulte SBW800...
2012 Toyota Avalon Sedan (A61569)
2012 Toyota Avalon...
2001 John Deere 6210 (A60462)
2001 John Deere...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2020 FREIGHTLINER...
