3 pt chipper info
/ 3 pt chipper info #2
I have sold over a 150 of the Jinma woodchippers in the past 2-years with No complaints,it's your choice you cannot get a woodchipper like the Jinma for under $ 3,500.00 ? You could buy 2- Jinmas for that.
Tommy
Affordable Tractor Sales
/ 3 pt chipper info #3
When I was looking for a chipper for my BX2350, the ones I looked at were the Wallenstein BX42 and two Bearcat models - the 73454 and 70554.
Went with the Bearcat 70554 as it's a nice 5" chipper and also has a shredder which it turns out I've used more than I expected. After (only) about 5 hours of use, it seems like a good match for my tractor and property. There are some previous posts on these models -- I would add that while the 70554 doesn't have a discharge chute, I haven't found that to be a big issue. Makes a good break to scoop up the chips with the FEL every 15 minutes or so.
The Jinma 6" looked a little big for my little tractor, and since it was my first chipper I wanted to have a local dealer who could help if needed. But the Jinma is a bargain -- as the previous poster noted, it can be had for less than you might pay for Wallenstein or Bearcat.
/ 3 pt chipper info #4
I went with the Bearcat 73554. I'm still using it a lot, and I'm still very happy with it. I changed (flipped over) the blades after about 15 hours of heavy use. At that point I learned how well it is designed. A single bolt opens the whole unit for blade access. I was impressed at how easy it was. I have also seen the 70554 in use - it's what sold me on Bearcat. You might do a search on Bearcat - you'll find other threads. I think in the end you'll get what you pay for.
/ 3 pt chipper info #5
Although Homier has gotten some bad press in the forum lately, I bought their (Farm Pro) 3PH Chipper last year. It has auto feed and will handle up to 6" however 5" & 6" stuff makes great firewood. I cleared a stand of saplings 1" to 5" to accommodate my 40x50 building with enough clearance on the sides and front & back to allow me to swing a truck & trailer. A lot of work. The chipper worked great, cost only $1200 plus shipping and gave me virtually no problems. I have since cleared more of my property and finally I think the blades need to be flipped over (alas, I have to remove two screws to get to them :D). Removal & sharpening will occur once the new edge dulls up. I have no complaints and am very happy with my decision to purchase.
P.S. Just checked the Jinma online ad - it's the same unit as mine.
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
42in. Pallet Forks (A65640)
42in. Pallet Forks...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
40ft Shipping Container (A65583)
40ft Shipping...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
