3 Pt chain hook up
   / 3 Pt chain hook up #1
alexinPA
NE PA (Lackawaxen)
Kubota B7800
I want to lift and move some mid-size rocks using 3 pt
Is there an inexpensive way to hook up the chains? And
if I use a cross drawbar (holed drawbar) what happens with
the upper link? Let me know if you have any suggestions/pic
I've read about chain busket and plywood dragging. So my question is where and how to attach chains to 3pt. Thanks.
   / 3 Pt chain hook up #2
Look at a quick tach design, and use the top hook to attach the chain. It will lift higher, but will require weight on the front of the CUT. Be careful.
quick tach thread
One of several threads showing the use of the 3 pt.
Thanks for the reply. I've been looking at quick tach thread
but can't picture how the thing look like. It's probably more
expansive than a cross drawbar anyway. Anything wrong with
just using cross drawbar?
   / 3 Pt chain hook up #4
Before I got my new tractor with the FEL, we used to use a carryall from TSC. It only cost about $70 or so and you can get an old skid and roll the rock onto it. I tried the chain thing to but it didn't work for me.
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
