3-Point Hitch 3-Point won't go down while running
/ 3-Point won't go down while running #11
The only other thing I can see is the linkage at the control valve itself that would lock your lever up.. Try and look at a parts manual.
/ 3-Point won't go down while running #12
are you mowing with a MMM or a 3pt hitch mower? ( do you have weight on the 3 pt hitch to push it down???)
/ 3-Point won't go down while running #13
You may not have this on your tractor but I once had this issue and I thought I broke my 3pt. I inadvertently engaged my draft control to full on. When I attempted to lower the 3 pt, it only went down a small amount. I later realized the error, turned off the draft control and it worked normally.
HP
/ 3-Point won't go down while running #14
I'd vote for the rate valve knob under the seat. It seems to fool a lot of people....
Ok guys. Weird stuff here. I adjusted the rate valve and the 3 pt will drop fast sometimes but it won't others. I still have the problem. Sometimes while running the lever engages fine and the 3 pt drops fast, other times it barely moves. It eventually gets down but it is slow. Other times I have to kill the engine to get the lever to engage.
Grrrrrrr!
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
CATERPILLAR 924F WHEEL LOADER (A59823)
CATERPILLAR 924F...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2019 Ford F-450XL (A60462)
2019 Ford F-450XL...
