Box Scraper 3 point trench filling attachment?
   / 3 point trench filling attachment? #12
That is SaaaWeet!
That's an old JD model 80 blade out of the 1960's. I have this one at home and two at the farm, one angled & offset for road grading & one turned backwards for a 'bulldozer' (both inherited). They show up on CL around here frequently. I used it on my JD 520 & now with the 790. ~~ grnspot
   / 3 point trench filling attachment? #13
Thanks, to answer a few questions, I'll be digging with a trencher (riding probably). Will be laying several hundred feet (maybe 500-700 before I'm all done) so I don't care to use a shovel. I have a 31hp tractor with box blade, but I don't think that will work well. I have a front end loader but that's a bunch of starting and stopping, the box blade would work better.
I like the idea of ...
"Buy an old, cheap back blade that will pivot around backwards. Cut it down the center and weld it back together so it forms a 90 degree "V". Then when you go backwards the "V" will fill the trench from both sides. No chance of cave-in."
That's probably what I need to do.
Covering the ditch behind a trencher for 700 ft is a small job. Most ride on trenchers have a blade to push the fill back in, some have a small backhoe on the opposite end instead. You should be able to cover this with your small tractor using the boxblade or fell.
2018 Infinity QX60 AWD SUV (A55853)
2018 Infinity QX60...
JOHN DEERE 4320 EHYDRO TRACTOR (A57192)
JOHN DEERE 4320...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A57024)
2017 Yale GLC050VX...
Mobile toilet (A53424)
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
